• Jim Bentley
    I was wondering how you deal with the plastic welds on the back of door panels ,such as taking them apart, and putting them back together.
    i drill the heads off and use self tapper screws to re fit and sometimes use a hot glue gun as well
    What glue do you use in the hot glue gun Chris as the ones I've got don't seem to stick well?
  • Cesar Chavez
    I agree with Chris, just cut all of the plastic heads off to remove the insert panel. Before putting it back to its position I drill all of the studs just enough to let in a small self-drilling wafer screw. If necessary a small washer would help to keep in place the screws. Some resin over the heads would give an original appearance.
    I do the same as the others. Cut the heads off and reattach with a self tap screw.
    What do you guys do about the mirrors on sunvisors? Some of them use the same method of a melted down plastic stud but it's much too small to screw it back together like you would a door panel insert. I recovered a pair for an early 2000s Honda Civic and had to eliminate the mirrors altogether. I do my best to save the mirrors whenever I can by tucking the material under them but sometimes I'm forced to eliminate them.
  • Michael cullen
    Hot air gun and plastic rods like they use for repairing bumpers.
  • Jesse Durkee
    I use either screws or epoxy for the door panels. The high temp glue doesn’t work that well for that. But it does for the sun visors. Although I did have a picky customer that decided to take it apart and I had to use epoxy. I use 3M 04247 it takes a special applicator and tips. You have to be incredibly fast as the set up time is like 30 seconds, then you have to switch tips.
    just the cheap clear suff but if its not strong enough then ill use the twin tube epoxy but more expensive and shorter shelf life once opened
    I prefer the self tapper screws. But sometimes there ist not enough material thickness. In this case just fix it with some hot glue poins but for the durability I use the black adhesive stuff you use for windshilds.
  • Ryan Welsh
    I've used products by 3M and Fusor made for plastic bumper repairs. They come in different strengths and speeds too. They aren't cheap, but They work great.
  • Warren McClung
    Norton structural adhesive number 5. You have to look at the type of plastic it's made of because with <PP> and other tpo plastic you have to use adhesive promoter to help it stick. I don't use the tip. I just squirt some out on card board and stir with popsicle stick and use the stick to dab it down in. I clamp the panel in place first.
