• Clay Hurtubise
    Hi
    I ran into some problems when sewing with new thread. It is only slightly thicker than what I've been using. Guessing it's either a needle size issue (though thread goes through eye easily), or a tension issue (need more or less?) thanks in advance.tfznxzsbiqntra83.jpg
  • Clay Hurtubise
    Machine is a Juki DNU 1541.
  • Clay Hurtubise
    Problem solved.
    I also posted this to a group on FaceBook, and came up with several suggestions:
    Replace needle (I do this this frequently)
    Loosen tension (I did this)
    Lengthen stitch ( I also did this)
    Problem still existed, but only with that particular thread. I replaced the whole spool, voila, problem solved. Turns out it was an old spool and the thread was sticking together.
    What brand of thread was it? It seems lately I myself and reading a few other problems that new to us, spools of thread, are old and causing issues. Is this a supplier problem of over ordering and sitting on the shelf too long?
    I used to have that problem in that the suppliers would store the thread in a hot environment in the summer and if the thread had any wax as lubricant it would melt and stick the thread together.
    Thanks for sharing the solution with us @Clay Hurtubise. This is really good to know, because some of our spools are ancient... best to replace them with a fresh spool before starting really important projects.
  • Clay Hurtubise
    It was a spool that I inherited from another trimmer, so I wouldn't blame the mfg (though I'll check if you want), but rather storage conditions. I'm guessing the thread is 5-7 years old, and when I first inspected it, it seemed fine. As I took more off, I could feel it sticking together.
    @Clay Hurtubise no you don’t have to check. Being that old anyways it makes sense.
    I discovered that also. Thread does have a shelf life. If you have boxed pre wound bobbins check them as well.
