There's an ongoing debate here at my shop about the direction the nap of the fabric should lay on the seat cushion when using Velour or like materials.... So I am presenting this question to The Hog Ring member forum.
Which way should the nap run on the seat cushion when using velour or like fabrics? (15 votes)
Should the nap run from the back of the seat cushion and go towards the front (rollover edge)
67%
Should the nap run from the front of the cushion towards the back
The nap should run down and out so you dont break (rub against) the nap during ingress and egress. Often times it looks better to run it the other way but it wont wear well.
