• Hollie Ketley
    Hi all,
    I am looking for a suitable adhesive film with flammability properties that you can apply using heat (heat press/iron etc)
    Something durable that will show no 'floating' off of the main surface fabric over time.
    Not bought from Amazon or eBay.
    Thankyou, I look forward to your replies
  • Patrick Ball
    Dont know what you are asking. What type application?
  • Spencer Andersen
    You want a hot melt adhesive film. They come in in web or an actual film but the downside is you need a full scale laminator or a large hot press to make the bond. The process is also known as leather laminating and they use it for everything in a oem factory to increase the weight of the materials by bonding to scrim foam, doorpanels, headliners, dashes, etc. The process used on seats will make them last way longer!
  • AJ Reid
    Spencer is correct but most Major US OEMs choose suppliers based on cost so sometime lamination isn’t done and it shows fast
  • Gareth Judd
    sounds like you would be better off with a water based heat activated glue
