Does anyone know where I could find some foam backed vinyl headliner? The color is MB95. Also, if I just get the vinyl, could I glue it to some foam or regular 3/16 headliner? Thank you, Hadrian.
Veteran has the right vinyl pattern/color but not foam backed. I ended up using that vinyl and glued some regular headliner to it. It made a couple of wrinkles in the back corners, but customer was happy with the end result.
