• Larry Schwantes
    Hey guys, just curious what machines you guys use when you do double top stitches, if you just use a single needle or a double needle. I did a chevy coupe in 2019 which had a lot of diamond pattern on seat inserts, door panels and trunk with double stitching which I used serafil accent thread on my old singer 144w305 long arm. It handled the job okay, it looked nice when done, but, man, that was a lot of passes to lay it all down plus staying attentive so the second stitch is evenly spaced with the first. Thinking about a double needle long arm as I have a couple jobs coming up that it would be really nice for, and it would need to accommodate the thicker top stitch thread. What do some of you guys use?
  • Abdul Osman
    We use a typical gc20606 double needle walking foot it makes the job way simpler especially for double stitched diamonds
  • Larry Schwantes
    Thanks for the reply. So, the double needle was a sizable investment. Did you ever second guess the investment or was the benefit well worth the cost? I ask because I’m a one guy shop, would love to have a double needle, long arm one would be better yet, but have to justify the expense. So I’m debating between a new machine, a used machine or just keep doing what i’m doing. I’d prefer a used machine but they’re hard to find. I know of an older long arm singer, but i’d have over $2000 in it by the time the gauge was changed. What’s a guy to do...
    I bought a Consew 339RB-1 several years ago. I am like you, a one man shop. I have seconded guessed the investment when it's not used but then when I need it, I'm glad to have it. I bought a rebuilt from Keystone . They do wonderful work as the machine is like new.
  • Larry Schwantes
    Thank you for your insight, that is very helpful. Have you ever wished it were a long arm? I guess the only thing I get hung up on is working on door panels, it’s nice to have the luxury of a long arm, but costs more. Bottom line, I think I am over thinking it, I could probably make good use of a standard length double needle like you guys have.
    A long arm would always be nice. I have a long arm single needle machine, but a double would be nice sometimes. I guess it's what you want to invest for very limited use. Myself, I can't justify another long arm.
  • Abdul Osman
    in all honesty it took me a while to get used to using it I would recommend getting a guide foot for your double needle machine ,dedicating threads for the double needle once it is set up and you have the hang of it , it really will save you a lot of time ideally you could get your French seams done in half the time it is a great investment you will never go wrong by having extra machinery this will ultimately make you more efficient time equals money in our trade and well if you can do a French seam with minimal effort like on the double needle machine then why not
  • Tim Snider
    I have a Consew 339-4 regular machine have never regretted it I quite often see 48in by9 foot precise for semi truck sleepers a long arm would be nice but I make it I also have a juki 1760L post machine I do a lot of French seams on it’s a beast I’m also a one man shop but these machines save me a lot of time
  • Larry Schwantes
    Thanks you guys, this is exactly the input I was looking for. I definitely need to move on something, what it will be is yet to be determined, i’m considering all your comments as I consider this. And a post machine, I didn’t think of that but I can see where there would be times that would be slick as well.
  • Joshua Etchison
    I have a Consew 339RB-1 that came with a 3/8” needle head. I changed it up to a 1/2” to do car upholstery and love it. Not a bad deal for $600. Runs good if you get the thread tension adjusted right. But I always have to really run a lot through it to test it. If I run 1’ piece it looks good. Then about halfway through a seat one of the threads start to fray and the thread breaks. If dialed in right it runs like a champ.
    If you're looking for a solid double-needle, the NC11 is a workhorse. You can even get it as a long arm, which is pretty sweet. Talk to @Mal Maher at NC. He can give you details.
  • Jason Bos
    I just bought the NC twin needle post bed and it’s great! You can even pause one needle and run one side only. mbyzko1s08m4qpsa.jpeg
