    hi guys im just having workshop revamp and plan on making a large table for marking and cutting leather with low bottom shelf to store rolls of fabric but on heavy duty caster to move it around so has anyone else done this and what size have you done ?? and do you have any pics ??
  • Dean McConnell
    My leather cutting bench is an 8ft x 4ft surface but I find myself wishing it was wider so the hide doesn't hang off the edges as much. When I get around to it I'll add a wider surface but it's one of those jobs that isn't really a priority but continues to irritate me!
  • Nick Lupien
    My bench is 70"x12'. I also have a sewing mahcine on one end of it with an infeed table behind it. adding to the length making it about 22' in total length. The bench is large but I can fit an entire hide on it. It is also nice to be able to roll out a 60" roll of topping and not have one side hang off the edge. the bench started its life in a trim shop in the 1960's.
    I have what you aim to make but not on wheels. It's about 60" wide by 90" long ...perfectly wide, could do with being a little longer ...100" maybe.
    my current bench with sewing machine is 6ft x 14ft which is perfect for rolls of fabric and vinyl which im keeping but having an additional one so want to have a top for it in one piece rather joins just for leather so might be using a 5ft x 9 ft sheet of MDF ..... will put pic up of current pic but please share yours as well
    All pieces are on wheels with locks. Top of the largest piece has a self healing cutting mat. Storage and power strips mounted underneath.
    www.phillocraft.com check these guys out. I have the 72" wide version 12' long (3 sections) the sections fit together licely.
    my current bench with quick fit sewing machine extension .
    its 14ft by 5.5ft in total
