• Warren McClung
    Oh how I dred plastic windows in tops. Anyone have a way to put these on without that minor scratch? I dont wanna touch the plastic at all. But there is always that one place that touches something or my head bumbed it and it needs cleaned.
    I put a thicker masking tape over the window on both sides. Works good for me. Doesn’t leave residue.
  • Sean Todd
    We use saran wrap. Stretch it over the window and gently press on and it should stick right to the plastic window. It also peels right off when the top is finished. Just don't let it bake on in the sun. Get it in bulk at costco or a restaurant supply place.
  • Robert Webb
    I use a low tack protective film that sticks to the plastic and then peels off with no residue. No more trying to get tape to stick to vinyl or canvas.
  • Warren McClung
    Im definitely giving saran wrap a try. Thanks a bunch for the tips.
  • Ryan HuffakerAccepted Answer
    I do alot of backdrops in jetboats out of clear .30 vinyl. They are pretty big so I bought some closeout 1/8" foam headliner I roll out on my bench so I can move and slide them around and they dont scratch at all.
  • Adam Gabriel
    we buy car cover material from Trivantage. Called Matrix or something like that.. we roll it out on our table and staple it down so it doesnt slide. Company I worked for prior made sewn covers with elastic on the edges and put over top of their tables.
    Ill also give the customer this material for when they store it. I give them enough to cover all the panels.Its cheap, 3-5$ a yard
  • Robert Webb
    I think he means when installing on the car
    If we're making the window, we sew it with paper -- and then rip off the paper when we're done.
    If we're just installing, we tape paper on both sides, and then just remove after installation.
    No scratches. No problems.
  • Warren McClung
    I used 3m contractor grade masking tape and it left tape marks behind. Tried mineral spirits and its not coming off.
  • Warren McClung
    I dont recommend using masking tape or any other tape. The glue on the tape had a chemical reaction the the clear plastic window leaving the texture of the glue embedded in the window. Electron doesn't recommend using tape either.
  • MICHAEL TODD
    We have been using clear plastic wrap for years with no problems.
