It never actually dawned on me that this was a thing. I spent my entire childhood in my father's garage doing exactly what this horse is doing while he installed convertible tops.
"Hold it here, don't let it move... you're letting it move, keep it right here.... ok raise the top a few inches and hold it there... no that's too high, bring it down a bit..." :lol::rofl:
I busted my arms every day holding up convertible tops for him. Meanwhile, y'all were using these??
I use the box that the top comes in to hold it up. Like the 2x4 method you guys are using.
The un-opened end of the box put under the center of the header bow. It's usually strong enough to hold the top. If it isn't, I stuff the old top inside. Tape up the opened end.
It can flipped around to hold it up high or just off of the windshield, by a couple of inches.
When I was first learning tops, the guy teaching me did that. It's the only way I've ever done them.
Both those methods posted are new to me!
Besides, with my luck, one way or another, that 2x4'd get knocked out & it'd drop.
Scratch/dent the hood. (Tim 'The Tool Man' Taylor voice.) "Oooh Nooo."
Or fall inside & rip something. That I can do something about. The first? Well...nope!
Maybe it's just me, but I'm more than just a bit paranoid of anything happening to a customer's vehicle while it's in my shop.
Nothing hanging on the one wall next to the vehicle.
Ladders out of the bay.
Brooms on the other side of the shop.
Lights on tri-pod stands are moved away past their distance of reach. (Trip on a chord? Down goes the light. Happens too easy. Spare bulbs are in the toolbox.)
Have one air line with a connection in the middle. Made a Vinyl/Velcro cover.
Some of these vehicle's paint jobs are worth more than both my trucks, combined. Damaging one is the stuff of nightmares. For me, anyways.
Looks much safer...
I have been using the 2x4 since the 70's
Back in the day Treon Manufacturing ,which was located where ET Tops is now,
would supply a piece of 2x4 , with Treon burnt into the wood, to lift the top
so you could unzip the rear window.
Looks like we will be building a horse ....
That's a great idea with the horses. I use a wedged foam block . Let's us adjust to different heights and add foam to it as needed. I don't have to worry about damage when it falls which unfortunately was learned the hard way!
