Branching off the recent patternmaking discussion... I like the undersides of my motorcycle seats to look as finished as the tops of them, so I don't like to just stretch the sides over and rivet or staple to the pan.
Instead, I pattern out a separate piece with a top stitch.. but I'm finding that I dread making this piece. Sometimes I lay my seat pan on the material and trace around it, I've tried pinning clear vinyl and creating a pattern that way... I've also tried laying a piece of trunk material down so you can't see the staples at all.. but I'm still not convinced of any single method.
What are your techniques for dealing with the undersides? Is there any industry standard? What do you think looks the best?
Just for reference, most of the seats that I'm doing are leather and most of them are on plastic pans -- although I do get some steel every now and then.
Hey Melvin, thanks for the suggestion. I had to use hidem for one of my first marine projects a little while ago and you're right, it does look really nice.
I'm curious if anyone has an unexpected technique.. for instance, I heard somewhere that some people will run a wire through a sewn channel in the seat cover and twist it until it's tight underneath. No staples or rivets involved. It sounds interesting but I haven't tried it.
Not sure it would work fine on motorcycle seat. You may have here and there some loss of tension. Also, would you like such underneath with a leather/vinyl band full of wrinkles?
This is a hard one. I find myself removing staples and having to readjust the cover way too often. Using the trunk lining material would work best for me but usually I don't bother with it.:D
I've recovered hundreds of motorcycle seats over the years, and with the exception of the few, where the customer has specified they wanted a under liner applied I do not cover my staples or rivets and have not had a single complaint. Keep the staples running in the same direction and uniform, trim excess material.
When I do have to hide staples, black Deck Master is what I like to use. It doesn't fray when cut and glues real nice
I like to use the trunk fabric on mine as it sits right on the fender and anything hard rubs the custom paint. But one thing I’ve also done is make a bottoms pattern maybe an inch or 2 wide to perimeter the seat pan. Make 2 of these and sew them to the cover. Lift the top piece of the 2 and either staple or rivet the bottom. Once you let the top cover flop back it hides everything on the bottom piece of the 2. I don’t have any pics but can sew something quick if that makes no sense lol.
