• Ron Rieger
    Hello looking for some info as if you guys use sew foam on your motorcycle seats? If your using the same process as your auto seats
    Thanks
    Ron
    I don’t on the seats I do. Only time I do, is when a design is sewn into the cover and needs it.
  • Justin L Rash
    Remember also when doing certain stitches in motorcycle, atv, dirt bike, etc seats they are more vulnerable to foam saturation unless wrapped with a barrier. I’m still on the fence about wrapping foam with plastic to prevent saturation. I do a lot of boat work and see it from the factory all the time but I also see when a customer doesn’t maintain their boat and it builds algae and mold under the plastic on the foam causing a mess and rapid deterioration.
